Airbag Code 52 help | Ford Explorer Forums
Airbag Code 52 help
Timbrazer
Hey everyone,
I am new here.
I have been searching and searching around for more answers on help with Airbag code 52. My airbag light flashes 5 times, pause, then 2 times. I have found the reason on many forums including here. What I did was I took the airbag fuse out instead of the 4X4 fuse out of the Power Distribution box under my hood and drove around for a couple of minutes with it out.
I know there is nothing wrong with my airbags since I just removed the fuse and put it back in. But now that this code is in the NVRAM, the airbags won't deploy in an accident.
I am currently trying the on/off ignition trick where you turn the ignition on and off 256 or so times and the code will be cleared from memory.
My question:
Is there any special way to do this?
Can I just flick the key back and forth?
Do I have to wait till the code flashes and then the airbag light stays lit and then shut it off and repeat?
Do I have to shut it off before it flashes the code?
Is there any little thing of just the right time to shut it off and then turn it on again?
I am just really confused. I've been sitting in my car 30-45 min. here or there just turning it on and off and I've lost count. I'm not sure if I have done it 256 times...
These are the forums I have read so far.
http://www.explorerforum.com/forums//showthread.php?t=154053
http://www.ford-trucks.com/forums/25500-air-bag-light-flashing.html
Thanks for any help you can give me :)
