Alignement/tires? | Ford Explorer Forums
Alignement/tires?
taxx
Make em say Ugh
Indianapolis, IN
73 EB
OK this one could go here or in tires I guess. But I will ask here since it is alignment related.
When you go to bigger tires (the only change) like from 31 to 33 does that affect the alignment at all? THis may be a stupid question but I don't know too much about caster/camber and all that jazz.
Just changing tires does nothing to the alignment. However, if you raise the suspension at the same time to fit the tires, you will have to do an alignment.
That is what I thought but I just wanted to check!
Thanks
