Alignment Issues | Ford Explorer Forums
Alignment Issues
AJRK
Toronto, Ontario / Rancho Mirage, California
'00 Limited
Is there any specific problem with negative Camber alignment on this generation of Explorers? I've noticed some look very much like the front tires are angled in (negative camber), and I notice the inside tread blocks on my tires are starting to wear more than the outsides. The car still tracks straight, and has never had any problems with the front end. The only parts I've replaced up front are ball joints.
2000 Limited
2000 Limited
You may need camber adjusters for the upper control arms.. Also check your upper balljoints for play.. They are notorious for failing prematurely.
