Alignment | Ford Explorer Forums
Alignment
adamsbro2
Bryan
Twin falls, ID
93 XLT
Hi guys........I am getting ready to do a full width SAS on my 93 and i have been reading and reading getting all the info i can before i start. I have found tons of information and so far can only think of one thing i seem to be having trouble finding. When tearing down my d44 i removed the camber bushing from both ends. I have found TONS of information on the "C" bushings for caster but i cant seem to find any info on the threaded bushings for the camber. If anyone knows anything about these like generally what degree bushing is a good starting point, or a link to a thread or 2 that discuss this it would be greatly appreciated. Thanks in advance.
Found this......any thoughts or experience with these????
I never even knew Camber was adjustable on a solid axle. As I understand it, The Camber should be 0 if the axle is straight. Are you trying for a different Camber value or is something bent etc?
~Mark
~Mark
Honestly I didn't either til I pulled these bushings out and started looking into it.
If you mean on the straight axle D44, there usually is no adjustment unless the axle is bent or something is not straight. Do the screw in bushings (sleeves) have a centered or off set hole? If it is centered, then everything is good. Replacement bushings usually come with new ball joints. You need a special tool to torque the bushings to 50 foot pounds, then the ball joint nut to 100 foot pounds. Here is a little helpful information to get you on your way.
Some Good Info on Dana 44 torque Specs
Ring-Gear bolts- 60 (lb-ft)
Bearing-cap bolts- 60 (lb-ft)
Diffrential cover bolts- 20 (lb-ft)
Front wheel-bearing lock (outer) nut- 160 (lb-ft)
Spindle to knuckle nuts- 65 (lb-ft)
Lower ball-joint nut (first pass)- 30 (lb-ft)
Lower ball-joint nut (second pass after upper
is torqued) -70 (lb-ft)
Upper ball-joint nut- 100 (lb-ft)
Adjusting ring-to-end forging (sleeve)
(upper ball joint) - 50 (lb-ft)
Steering arm to knuckle arm nuts- 90 (lb-ft)
U-bolts to axle- 150 (lb-ft)
Wheel lugnuts- steel wheel 88 (lb-ft), aluminum- 100(lb-ft)
The bushings I pulled out looked like they were centered and not offset but why do they make different offset bushings if they don't have to be messed with?
It is the only way to align camber on a solid axle is something is out of spec. I think there is only one type of offset bushing. My solid axle is less than 1* off on the driver side, and if I cared, the only way to correct it is a offset bushing. It doesn't effect tire wear, or the way it drives so I am not concerned.
Ok....that's good to know....thanks guys...yall are the reason this forum rocks
