scott11202
- March 11, 2005
- Davenport, Iowa
- '93 XLT
I recently put a 2 " suspension lift on my 93 explorer 4x4 using the skyjacker lift coils and the f-150 leafs in back. After the lift I got an alignment done to make it drivable knowing that the springs would sag. the shop couldn't get the camber perfect so it has a slight +camber, \--/. It has been about a month and the springs still haven't sagged as much as i had expected. The alignment shop used 3 1/2 Camber bushing and I can't see that there is any larger out there to use. I was hoping not to need drop brackets but it is seeming that I may need them. Does anyone have any suggestions on what to do? I just need to get this figured out before fall so I can get new tires for winter. Thanks.
