All Power locks will UNLOCK..but not lock? every door affected | Page 2 | Ford Explorer Forums
depending on how you got "most of them to work", the "infamous splice" in the rear left pessenger side OR a broken wire in the driver door post.... probably the driver door post
update on mine:
Pulled the seat out and looked at all the wires. nothing was crimped or looked out of place.
So I pulled the panel off the door and started to look and mess around. Located the lock actuator and found that it was not attached to anything. Did not know where it was to be attached. so I pulled the drivers side panel off an found that it was rivet to the door. Went back and saw where it was jb welded to the door at one time. Was going to by a rivet gun and rivit it back to the door. But was not going to pay the $10 for the gun and then $15 for a box of rivets when I only needed one. So I used a 1/4 by 3/4 hex screw with two washers and a nylong nut to prevent from backing of easly. I had already held the actuator and play with the locks and it worked. I drilled out the rivet from the bracket of the actuator. I super glued the washer the the nut. Inserted the nut in the wrench and then taped the outside so the nut would not fall out. put the actuator back in and lined it up and put the bolt in.
All is working great now.
Now down to two things on my list: Was down to one but found one out when I was messing with the door.
Lamp Reading Bulb: Cant buy those at any autoparts place. Appears I am going to have to go the the dealer for that one.
And the new one, the passenger window switch does not work. but the driver side does.
Almost done. Thank you Explorer Forum.
Donnie
keyless entry pad doesn't work or doors dont lock with remotes
Yes pink and yellow/stripe wire corroded. Beside drivers side rear seat at door jam maybe under trim/step plate. Mine was covered by factory shrink tubing and part of it was under the black plastic wiring cover channel. Cut factory heat shrink tubing off and repair wires.Problem solved!
Keyless entry pad doesn't work
Doors don't lock with remote or any switch except rear cargo door lock switch
My to-do list on my newly acquired 96' Limited Ex is pretty extensive, with most of them being petty little electrical things, and this is one of them. I almost cannot wait to leave work to go pull my rear seat/carpet and check this out. I hope this fixes my no power lock problem!!! Thank you Explorer Forum! Truly a wealth of information on here! :)
And that did it! :D Soldered then shrink wrapped the wires and locks are fully operational now! On to cruise control and front window regulators now :).
This Fix my problem it was the P/Y wire connections.
i thought this thread could really use a picture of what you'll expect to find, since I'm currently on the hunt to fix the same issue.
All the wires were snapped off and green even though theres no exterior damage the covering.
I patched these 5 wires back together, but my locks aren't firing yet, so i must have another break somewhere. Also i have a dead remote starter that i think may be contributing to the problem.
update. This was the pwr lock connection i was looking for - what was left of it! I found it a little further down by the door. I don't know what the first splice that i fixed was for.
hope my pics help someone out
Sorry to post the same thing multiple times, but I wanted to post my solution in all 3 of the threads that helped me. Also - many thanks to all the people that provided the power lock info, wiring diagram, and repair tips. I would have never figured it out without your help.
My problem- drivers side power door lock switch would lock all doors, but not unlock any. Passenger side door lock switch and cargo area switch both worked fine, locking and unlocking all doors. I assumed it was a bad switch, and bought a replacement from an ebay junkyard for $15. I installed it, but it did not change anything.
I tested the switch wires inside the drivers door and found the following:
Pink with Yellow stripe (lock wire) had 12 volts.
Pink with Green stripe (unlock) had 0 volts. <<---problem
2 black wires were ground.
Red/Black wire was ground.
In the cargo area, I opened up the jack storage door under the door lock switch and had access to its wires. I think there were only 3 wires:
Pink with Yellow had 12 volts. (lock)
Pink with Green had 12 volts. (unlock)
Black was ground.
At the drivers door switch, where I had no power, I tried jumpering power from the Pink with Yellow over to the Pink with Green. That allowed the switch to get a "thunk" reaction from the door lock actuators, but they still didn't unlock.
I tested the 2 Pink with Green stripe wires in the jack well by piercing the insulation with a pin and testing for voltage with a multimeter. both had 12 volts.
I opened up the sill plate along the drivers side, and opened up the black plastic wire chase, and found two pink with greens in the trough. I test both at several places, including under the rear seat AFTER the splice point, and along the side at rear seat and drivers seat. both wires had 12 volt at all points except inside the drivers door. I did open up the splice point. Mine was just as it turned from the sill plate to go under the rear seat. It was fine, with power in both wires on both sides of the splice.
I read another thread that described how the wires feed into the door, through the black barrel looking connector. I removed the drivers side kick panel and found the Pink with Green and tested it for power by piercing it. It had power. There were actually two, one going into the door and another continuing towards the firewall. I disconnected the barrel, and then disconnected the rubber boot at both ends. Followed the Pink with Green into the boot - and BINGO! broken wire inside the boot.
i used a piece of wire about one foot long, and fed it through the boot. i spliced it in with butt connectors and each side of the boot, and pulled the excess wire into the kick panel. reassembled the boot and barrel connector and tested it and it worked!!!
in another thread someone described how to open the barrel connector. I'll repeat that here:
disconnect battery...
on the top of the barrel, find a plastic plug and remove it. under it is a 10mm bolt head.
unscrew the bolt and see the plug begin to drop down. unscrew it until the bottom section comes completely loose from the top section. cut the wire tie around the boot, and then pull the boot from the door jamb opening. you can slide the boot back and forth on the wires a little, enough to tug on the one you are interested in and see if it falls out broken like mine did.
thanks again to all previous posters. my drivers side unlock finally works again.
First post on this forum. Have to say, I love this place! Lots of good info here especially in this thread.
My problem was similar to everyone else's here. Doors would unlock with remote, unlock/lock with rear toggle near hatch, no other toggles worked nor could I lock with the remote.
Without using a multi meter or continuity tester I went with the advice given here and removed the rear drivers side seat. Lifted the carpet, peeled off the electrical tape from the bundle of wires and located the pink and yellow wires. Chased the pink and yellow wires from behind the drivers seat to left rear bolts that held the drivers side rear seat and seat belt down and found the splice where one pink and yellow wire met with three. It looked fine at a glance but after I cut the splice open I found the notorious green powder hidden inside. Trimmed the wires, re-spliced, hit the door lock on my remote and voila! Tested all the lock toggles and all worked as they should. Hearing the door locks function was music to my ears!
A big thanks to all who contributed to this thread and this forum! You guys sure saved my wallet and there is no greater satisfaction than doing your own vehicle work, especially when it WORKS!
-GiX
Thanks all. This fixed my 1999 limited. Connection under rear passenger right by door jam. Connection looked good until I peeled back heat shrink and wires were broken. Quick solder job and they work fine.
