kps36
- February 19, 1999
- Matthews, NC
- 95 Sport 4x4
I have been getting a CEL (Check Engine Lite) since the beginning of summer. It lites up when Ex reaches operating temp. It has 82K on it, so last w/e, I threw about $400 at it. I did the following;
New Bosch+4
Cleaned the K&N
Cleaned the MAS
New O2 sensors (not that hard, 15 min. per side)
New FPR
New PCV
Changed oil
ATTEMPTED to change the fuel filter, will try again
New IAC (I took it off and cleaned it, upon reinstall it sounded like a VERY loud shop-vac on wheels)
I then unhooked the negative cable over night, and sure enuff, IT CAME BACK.
Trucks runs fine, mpg better, but, get this..at a constant 46mph (CControl on) it feels like a very slight hesitation, VERY slight.
I have checked all vacuum lines, alls well.
I seriously think this HOT weather here has something to do with it. I even did the old GM PCM clear method of pulling the 2 PCM fuses (13,19 on mine) and turning it to the 'ON' (not start) position for 10 minutes.
I think the fuel filter is only 30K old, but I want to change it out anyway. I got the 'tool' but it won't budge.....AGHHH
That new Mustang 'Bullit' at $26.6K is looking real good right now.
Just venting.
ANY INSIGHTS ???????????
New Bosch+4
Cleaned the K&N
Cleaned the MAS
New FPR
New PCV
Changed oil
Just venting.
