Pirate explorer
- January 18, 2014
- 2000 5.0 explorer
I have a 2000 5.0 awd the alternator quit working so I replaced it the new one I got was a reman and it was bad also when it was tested. I had the new tested before I left the parts store it was good I put it on and it would not charge I put new battery cables on. The cable from the alt. to the battery is good I have power there the chilton book says to check the plug coming out of the voltage regulator there should be 12 volts coming out of one wire and 1 volt out of the other when the key is turned on I have the 12 volts at the one for 12 but nothing coming out of the that is supposed to have 1 volt please help me find the fix so my alternator will charge
