Amp Specs | Ford Explorer Forums
Amp Specs
Dan Whitaker
One fast putty tat
Raytown MO (Kansas City suburb)
No Mounty no more.
JL Audio e1800D
640w RMS @ 4 ohms @14.4v
1000w RMS @ 2 ohms @ 14.4v
Sundown SAZ-1500D
1500 x 1 watts @ 1 ohm
800 x 1 watts @ 2 ohms
400 x 1 watts @ 4 ohms
0.2v - 6v adjustable input sensitivity
10 Hz - 350 Hz Frequency Response
>90 dB dB S/N Ratio
4-Way Protection Circuit (Thermal, Overload, Speaker Short, and Over Current)
Linkable to another SAZ-1500D for up to 3000 watts @ 2 ohms
35 Hz - 300 Hz adjustable 24dB Low-Pass Crossover
10 Hz - 60 Hz adjustable 24dB Subsonic Filter
0 - 180 degree adjustable phase shift
0 - 18 dB adjustable bass boost with 45 Hz center frequency
Wired Remote Control unit included
4x 40 Amp Internal Fuses
17" L x 9" W x 2" H
Sundown 100.2 and 100.4 specs
SAX-100.2
100 x 2 watts @ 4 ohms
200 x 2 watts @ 2 ohms
400 x 1 watts @ 4 ohms bridged
Damping Factor > 200 @ 4 Ohms
10 Hz - 40,000 Hz Frequency Response
Channel Separations: 75 dB
> 90 dB S/N Ratio
Selectable HP / LP / FULL crossover
35 Hz - 300 Hz adjustable 18dB Low-Pass Crossover
75 Hz - 2,000 Hz adjustable 18dB High-Pass Crossover
3x 20 Amp Internal Fuses
13 3/8" L x 9" W x 2" H
SAX-100.4
100 x 4 watts @ 4 ohms
160 x 4 watts @ 2 ohms
320 x 2 watts @ 4 ohms bridged
> 90 dB S/N Ratio
CH 1 & 2 Variable HP crossover 50 - 5000 Hz @ 12 dB
CH 1 & 2 Variable LP crossover 30 - 250 Hz @ 12 dB
CH 3 & 4 Variable HP crossover 50 - 1000 Hz @ 12 dB
CH 3 & 4 Variable LP crossover 50 - 5000 Hz @ 12 dB
10 Hz - 100 Hz variable subsonic filter (CH 1&2 and CH 3&4)
Subsonic filter allows for band-passed crossover configuration
35 - 120 Hz Variable Bass Boost Center Frequency
3x 30 Amp Internal Fuses
16 1/2" L x 9" W x 2" H
__________________
Hey could you add my 2 amps specs to it?
MB Quart DSC 1000.1
1 ohm: 1000 watts x 1 chan.
2 ohms: 500 watts x 1 chan.
4 ohms: 350 watts x 1 chan.
Variable input level control: 0.2V-0.6V
Frequency response: 15-250 Hz
Variable low-pass filter (35-250 Hz, 24 dB/octave)
Subsonic Filter (15-35 Hz)
Tuned Bass EQ (0-9 dB bass boost at 45 Hz)
DC, short, thermal, and overload protection circuitry
Wired remote bass level control included
2x 60Amp Fuses
19.69"L x 9.45"W x 2.7H
MB Quart DSC 280
4 ohms: 320 watts x 1 chan. Bridged
2 ohms: 160 watts x 2 chan.
4 ohms: 80 watts x 2 chan.
Frequency response: 10-20000 Hz
Variable high-pass filter (10-1200 Hz, 24 dB/octave)
Variable low-pass filter (30-150 Hz, 24 dB/octave)
2x 20Amp Fuses
10.24"L x 9.45"W x 2.7H
Soundstream PCX-1000D
Monoblock - Class D
RMS @ 4 Ohm (14.4v) - 500w x 1
RMS @ 2 Ohm (14.4v) - 800w x 1
RMS @ 1 Ohm (14.4v) - 1000w x 1
Signal-to-Noise Ratio: 100dB
THD: 0.30%
Dimensions: 17"W x 10"Lx 2.5"H
Audiobahn A8002T
Dual Channel - Class A/B
RMS @ 4 Ohm (14.4v) - 200w x 2
RMS @ 2 Ohm (14.4v) - 400w x 2
RMS @ 4 Ohm (14.4v) - 800w x 1 (Bridged)
THD: 0.02%
Dimensions: 11-7/8"L x 11-1/16"W x 1-7/8"H
Phoenix Gold ZX475 Ti
4x75 @ 4 ohms
4x150@ 2 ohms
2x250 @ 4 ohms
Tested power 543.6 watts 2 channel @ 4ohms
Sub Amp
JL Audio 500
500 watts x1 @ 1 to 4 ohm
How about specs for factory amps?
JL Audio e1800D
I have a94 Eddie Bauer a JBL factory amp that have been cut and I want to know which wires are which for both plugs of the stereo amp to get the system back to factory. Pics would be great too. Please please please help. Thank you
