Iron-Mike
- May 30, 2006
- Boston, MA
- '00 Limited
I've been living with alternator whine in my system for awhile now and I decided since I had my dashboard apart yesterday I'd try to get rid of it once and for all. I double checked all my wiring and connections and I believe that the ground noise is coming from the RCA terminals on my deck. I'm using JL Audio interconnects so I have shielded cables to begin with. I went as far as using totally separate interconnects and hooked them up to the terminals on the back of the deck and ran them straight acros the seats to the cargo space and into the amps. Still got ground noise so i know its not the way I ran the RCAs and speaker wire. (RCA and speaker wires run down the passenger side, power runs down the driver side. Remote turn on wire runs down the passenger side too). I have both amps grounded to one of the rear bench bolts and power comes from a fused 4 ga connection from the battery under the hood to a fused distributor block in the rear.
Anyone with suggestions on how to eliminate the ground noise in this setup? I fell like I'm going in circles checking everything several times over trying to see what I did wrong but I keep coming up empty handed. Oh and by the way ground loop isolaters didn't work when I hooked them up at the amp end of the connections either in case someone was going to suggest them...
Thanks in advance for any insight guys
Mike
Mike
