Amplifier Turn ON? | Ford Explorer Forums
Amplifier Turn ON?
4x4username
Detroit, MI
99 XLS
Hi,
I could not locate the wire for "Amp /antenna turn on" on 99 Explorer.
What should I use to turn my amp on?
Thank You.
mb
Find a live wire when the key is in the start position AND the accessory position.
Although, I read somewhere that you might experience a POP noice when you turn on your radio and if this occurs you might need a delayed power source.
I have mine wired to a live wire when the key is on and I do not have any pop noise.
hope this helps you..
The only thing I could find was a +5V turn-on for the factory amp. Rather than splice into the wire and hook up a 5V relay to control a 12V source, I just used a 12V signal from the accessory. I ran it through my center console through a switch so that I could turn off the amp (which only drives my subwoofer) with the engine running should the need arrise (and it has).
Thank You.
I will use the accesory+switch approach.
mb
I'm pretty sure the factory amp turn on is the blue wire.
There is no blue wire in 99.
I think the wiring changed in 99?
-mb
The remote turn on for the amplifier in '97 (ASYS ON) is a light green wire with a black stripe. There is also what is called a "starter signal" that is red with a light blue stripe but it doesn't come from the radio. There is a dark blue wire on the radio but itis for the "logic mute".
