PashRoot
- April 23, 2013
- '97 Explorer 2WD
Because my explorer felt like I needed another challenge, I'm now losing coolant only when the engine is running.
This leak has been pretty tough to find and with all the rain these past 3 weeks, I'm only just now figuring out where it might be coming from.
- Oil dipstick looks good, no milky oil
- No white smoke from exhaust
- No unusual engine noises
- Coolant looks normal in appearance
So hopefully I've ruled out a potential head gasket issue. What I just noticed today is that I'm getting a little bit of dripping on the passenger side, underneath the engine. It ONLY happens when the vehicle is up to temperature. It's not the a/c because I have no working air-con. The minute I shut it off the dripping pretty much stops in a few seconds. I'll occasionally also hear a brief 'sizzle' once I shut off the engine as if the coolant is dripping onto the block, but not always.
My reserve tank is pretty full still and I'm not losing too much coolant, but it's enough that I'd like to fix it asap.
I've tried feeling around all the heater core hoses as well as the main radiator hoses. Everything feels dry (or it's evaporating too quickly?)
What's the easiest way to determine where the leak may be coming from? I'm having someone help me sometime tomorrow evening to look for things while I run the engine but I'm getting sick of wasting gas trying to find this darn leak.
First the bearings, then the tranny leak, and now this.. just make it stop already!
