pergolies
- May 23, 2006
- High Wycombe, United Kingdom
- 99 NorthFace
1999 4.0 sohl 4WD
I,ve had a whine (now a growl) coming from the front end for awhile now. First started noticing at about 65-70 mph but now you can hear it from around 20 mph and hits its peek growl at about 40 mph where the plastics (dash, vents, etc) start to vibrate before the pitch of the growl gets higher and the vibes stop. I had a similar noise on my last explorer and a change of hub sorted it. I presumed this had the same problem with the left hub because when i turn left the growl disappears (sure thats correct). Changed the left hub but the growl is still there! I doubt its the CV joint cos i dont get any clicking at full steering lock. Could it be the U joint? Dont see that could make that noise. I also noticed that when i go over uneven roads, the pitch of the growl/whine changes with the positive and negative g forces.
Appreciate any help
Appreciate any help
