Another quest …. | Page 7 | Ford Explorer Forums
Another quest ….
crank up your idle speed and it will smooth out when AC and headlights is on. You IAC might be bad. Idle should pick up when you add a load such as AC
Make sure you also buy a high quality gasoline with 87 octane (gasoline with fuel additives that remove water and deposits) I personally like BP gasoline. Before I was using Race trac gasoline (a division of shell Canada) and contained a lot of water in it (no additives), and they probably use the full 10% ethanol blend:mad: The owners manual for a 95 explorer , I believe asks for gas with no more than 2% blend-if you have to use it. Lets face it-the most probable cause for most peoples rough idle issues are from too much ethanol!
