Big Tuna
- October 29, 2017
- Lyman,Sc
- 1997 Ford ExplorerXLT
I have a 97 Ford Explorer XLT i bought used about 5 yrs ago. Over the summer, the car sat idle and the battery went dead. I replaced the battery the other day. I put in the new battery and when i went to start it the horn started blaring constantly. I disconnected the battery. I left it unhooked overnight, then tried hooking the battery back up, still blaring, hit the lock/unlock on the driver side with the door closed,still nothing. I have hooked it up and tried to hit the buttons on the keychain , still blaring. The vehicle will start with no problem, just the horn blares whenever the battery is connected.
Is there a way to disable the system? Will disconnecting the horn do the trick, or will it cause the battery to go dead because the antitheft system is triggered? I want to avoid taking it to the dealership as i dont want to put $300 bucks into it if i can help it as we only use the vehicle to take the kids to school(10 minutes a day monday through friday)and will be trading it in for a new vehicle in a couple of months.
