kmank
- May 11, 2011
- Danbury, Connecticut
- 1995 XLT
Me again, the guy whose power steering problem almost put him in the looney bin until you people got me headed in the right direction. That problem is becoming a slowly fading memory although that p/s pump is still "buzzing".
Anywho, my newest problem could have been caused by me and my shipyard skills at using the oxy/acetylene at loosing n burning off rusted nuts to using heat to free up the lower most transmission cooling line fitting from the radiator. I knew that most of those radiators are silver soldered together and that I had to be careful of the amount of heat I'd willing to use. Well, apparently I may have done some damage as I just noticed (after a good 3 or so weeks of driving), while chking my fluid levels that the antifreeze that was left in my coolant reservoir was the color of my trans fluid. When I removed the radiator cap sure enough there was a pinkish foam floating there. Then came the pulling out of the trans fluid level stick and seeing that it was coated completely with anti-freeze contaminated liquid. The car is safely parked and the trans is still doing its thing but I will NOT drive it anymore until I get this fixed. My question to you all (finally) is this: Is it time for me to replace the radiator? I just can't think of any other place where these 2 fluids can infiltrate there own space. There are no fluid leaks coming from the radiator or where the presure n return trans lines connect.
PS: I was able to free that cooling line fitting. Again. any suggestions or advice would be appreciated big time. Thanx gk
