Anyone currently using a Q-Logic stock replacement sub box? | Page 2 | Ford Explorer Forums - Serious Explorations
So next up is the Head Unit. Any good suggestions? For now I'm going to keep the Mach 6x8s...
Now I need to get setup for the Head Unit. Any suggestions? I want to continue using the Mach 6X8s for the time being...
Are you looking for a single-DIN or double-DIN unit?
I think head units are subjective, but I would definitely get something with a digital input, i.e. MP3 player input, whether it's a patch cord input like I have, or a regular rear hookup.
Look at the specs of some different ones- like I said, I was planning on spending about $200 for a good head unit, and the Pioneer I ended up with for under $100 had the same performance ratings as the much more expensive HU's just with no 'weather tracking' or radio song info recovery or stuff I don't need. All of hte controls and options are there, levels, EQ's, etc...
...I do love having a remote too...
I've always run Pioneer or Alpine decks, so I'm probably partial to those. But I guess buy what looks good to you and meets your performance needs and don't spend more than you need to for fluff you'll never need. :)
That Pioneer looks good, and it's pretty inexpensive. The only thing I don't like is that I've heard I'll lose the use of my 6 disc changer and steering wheel controls. I assume there might be a way to keep them hooked up, but I've never been to good at installing decks... Any ideas?
I dont think you will be able to keep 6 disc changer. Can you provide website where the Q Logic for cheap is? They are pricey, so a $5 Sub Box from el boneyard is more appealing if I could find one.
GRN- In about 2 weeks I'll be heading to the junkyard probably weekly, and can get one for you if you like, would just need some shipping, etc... :thumbsup:
Yes, you will lose your cd changer, but that's why I got the Pioneer with the patch input on the front. I can hook a patch cord from the front of the radio to my mp3 player and I have tons of music I can play, without the troublesome stock cd changer. The rear controls are also going to go, but with a 6yo at home, I don't miss those. :)
CD changers are like turntables....dinosaurs. My new CD changer holds too many CDs to remember (and a tad more than 6). It's called in iPod. Get a deck with some sort of direct iPod control and you're set. Mine connects to a cable that's in my glovebox. I don't even take iPod out of it's case. I also have my tunes with me at work, at home, while cutting the lawn etc. :D
Oh yeah, CD changers swallow up your storage space under the armrest. What's the point?
You can find kits that let you control your HU from your steering controls. It looked like a hassle to me (and not so cheap, around $70 if I recall). My Pioneer HU has a remote that actually connects to your wheel anyhow. Works great and gives you more options than the OEM controls. :thumbsup:
I like the use of CDs because if the files are .wav files and if the cd wasn't burned, I can definitely tell the audio quality is better. But, I also need to except 90% of my music is stored on my computer. Anyway, I think I'm just going to buy that Pioneer deck. It seems it's got everything I'll need, (including an input for .mp3 which all of you guys love so much!) Hopefully I can get everything shipped out to me by this weekend, so me and my grease monkey help can get going on this...
I really do like the patch cord input, and haven't had a problem with the deck at all. Plus, the green button lighting on the deck matches the green interior lights of your truck perfectly... I was never a fan of aftermarket lighting where everything was one color then I had a deck with red lights or whatever... :)
Joe D,
That is mighty kind of ya, any idea what shipping would run to Chicago land area? I would rather have a Q logic box with a 10" sub if money were no object but.... A $5 sub box sure sounds affordable!!
And if I understand correctly, the stock amp would still drive the 4 speakers. Another aftermarket amp would be needed for the sub and that would connect via RCA outputs on the back of the radio and a ground wire to battery would be needed? Dont u just love questions from audio newbies like myself.... Or is that audio dummies....
Grn Machine, If you get a stock box from the jumkyard, there is a good chance the stock amp is still attached to it. It's only 85 watts of power, but it will fill in the lows pretty well.
I bought that Pioneer deck. $82, shipped, brand new, not bad. Now I'm wondering if I should order the amp kit and wiring harness off the net, or just by them locally...
Grn- The box would probably be ~ $15 to ship to Chitown from here. It's a pick 'n pull, so I'd probably just remove the stock amp. They'll charge me $20 for the amp, and you can get the 400w amp I have for $60. Much easier to wire in, too. If you don't already have a sub, you have th change the entire harness to get it to work.
Faster- you'll be looking at $20 ish for the wiring kit, and $10-15 for the harness locally at most stores
Good! I should have all necessary components for an install this weekend! I can't wait!
I suppose I could get all this stuff cheap at wal-mart? (wiring kit, harness, polyfill)
Hey Joe, would you mind posting a shot of your deck? I want to see what it looks like installed.
Thanks for that info Celly. What sub are you running in your Q logic, and whats the deal with the box's install? Do they send you a new side panel piece? Would you mind posting a picture of it? If the 8" doesn't get me what I want, and I buy the Q Logic, I hope to find that Infinity 10". If not, maybe a JL 10W3v3 will fit...
And any chance of pics of the installed amp and connections for it?? Not sure what to make of a $60 amp (would not have considered it if not for your review) but, for the price, fact it will only be used for 1 sub, etc I am really leaning towards your suggestion.
Here ya go- I can keep my remote in the slot above, I rarely use the face controls :)
Yeah, I wasn't considering until I read the reviews. I figured that after reading them and talking to a buddy that has a larger one from them, I'd give it a shot- heck- I can buy two if needed for the same price as one. Otherwise, I get my sub and amp for the same price as a more expensive amp. It really does sound good... Very, very happy with it.
Here is the link to Soundstorm Labs website- they make a LOT of amps...
CLICK ME
This is looking in
I've just got it sitting under there for now, in the next couple of weeks I'm going to re-attach the wires to the connectors/shrink sleeve them, and run the wiring under and through the carpet.
Nothing contacts when the seat is down, which I like, that's why I didn't want to mount it to the back of the seats, as it would be in the way for cargo.
With the '98+ radios (most) you shouldn't have an amp in the back, so you should be able to mount the amp to the sub rack behind the rear trim. I could fit it on mine, but I needed to leave the factory radio amp for my stock setup on there as the system still ran the speakers through the stock amp/wiring and put my sub amp under the seat.
Joe, that little slot area where your remote sits; did you buy that or is it stock? Being that the stock head unit is so big, I'll need to add one of those tray spacer things...
