Anyone have a problem with the "Repeat" and "Shuffle" buttons not turning off?
Dr Plastic
Newport News, Virginia
'15 Limited FWD
On my MFT with update 3.2.2 I cannot turn off the Repeat button. Although it does not repeat it stays lit all the time? This also happens to the "Shuffle" button.
OzzieMike
Broken Arrow, OK
2013 Ford Explorer XLT
I've noticed the same behavior in mine with the Shuffle not turning off. I've also noticed that it doesn't always shuffle the tracks...sometimes it does, but other times it doesn't. (Using an iPhone 4S with the current iOS installed).
13Sport
Los Angeles, CA
2015 Explorer Sport
Shuffle is broken with ipods and iphones. It will shuffle and play, but the next time you turn on the car it will start playing unshuffled from the point it left off. The button will still have shuffle lit, but in order to turn it off or reshuffle you have to do weird combinations of turning repeat on and off, and shuffle on and off.
I ended up shuffling my playlists in iTunes prior to syncing to the iPhone. Its also unfortunate that iTunes 11 removes the ability to shuffle the order of a playlist, you can only shuffle the next up list. I figured out my own workaround for this too.
If there is interest I'll share, otherwise I don't want to type the whole thing out :)
13Sport
Los Angeles, CA
2015 Explorer Sport
I haven't determined if this is an iOS 6 only issue, I plan on testing with my old iPhone that is on ios 5 when I pick it up tonight
OzzieMike
Broken Arrow, OK
13Sport,
Thanks for your posts....this is what I'm seeing with my iPhone running iOS6 in my Explorer (running the newest MFT version). It shuffles fine the first time, but the next time you start the car, it picks up where it left off...unshuffled.
I will have to check my playlist when I get home, but I'm pretty sure I shuffled it in iTunes before syncing my iPhone. What I THINK may be happening on my car is that when it picks up from where you left off the next time you start the car, it rearranges the playlist by artist, ignoring the shuffle I performed on the playlist prior to syncing it.
I will try to confirm this tonite.
I would be interested in how you're able to shuffle the playlist in iTunes 11. (If there's a link you can provide with the required steps, it might make it easier for you?).
13Sport
Los Angeles, CA
2015 Explorer Sport
Randomize playlist in iTunes 11
Here's a walkthrough. I don't have a link to instructions somewhere because I haven't been able to find any, I figured this out a few days ago out of necessity.
in iTunes 11, enable the sidebar to make this easier (view -> Show Sidebar)
Here you can see my original "Demo" playlist that is clearly organized by track name.
First:
Create a new smart playlist (from file menu or from the + menu at the bottom left of the screen)
Second:
In the smart playlist options match on playlist, and select your original playlist
Third:
Select the "Limit to:" option, and put in a number that is AT LEAST the number of items on your original playlist (I just put in 99999). Make sure it is set to limit to items by random. Uncheck the "Match only" and "Live updating" options.
You will then have a new playlist that is a randomized version of your original
Optionally you can highlight all tracks, and then create a new regular playlist from them if you'd like to remove the "Smart List" (since smart lists based on other playlists don't work with icloud and itunes match)
I hope this helps anyone else that is having the shuffling problem. If you shuffle the list and then sync it to your iPhone/iPod then you can just leave the shuffle option on MFT off. MFT will play the list in the shuffled order that it was sync'd. I reshuffle my list every couple of weeks and resync it to the device. Has been working fine for me so far.
HDJulie
Little Rock, AR
2019 Explorer Platinum
The issue with the shuffle & repeat buttons & with the playlist no longer shuffling after a restart has been around since last year & has not been fixed through the last two updates. Super annoying.
OzzieMike
Broken Arrow, OK
13Sport,
Thanks for the detailed directions for making a shuffled playlist in iTunes 11! Wow! That was a lot of typing, wasn't it? (And wouldn't have been necessary if the MFT system worked as designed. Maybe someone needs to let Ford know that their definition of "good enough" needs to be tweaked?).
13Sport
Los Angeles, CA
2015 Explorer Sport
13Sport,
I blame apple here too. Shuffle/Repeat works fine on USB memory devices. Apple uses nonstandard ways of doing things. It also used to be easier to create a shuffled playlist in iTunes versions before 11. In iTunes 10 and below you could just hit the shuffle button while a playlist was selected, and it would shuffle the list in place. The shuffled list could then be synced/copied to the device. Apple increasingly makes simple things more difficult in order to better serve the people that need less features.
cnsheets
2011 Explemoner
Damn, that "Demo" playlist looks like something my 13 yr old listens to...
13Sport
Los Angeles, CA
2015 Explorer Sport
LOL.. your 13 yr old isn't old enough to know who the majority of the people on that list are =P I grabbed a random sample of a 20,000 song library, I was bound to get a few good songs in there :)
Glad your 13 yr old has such good taste though, it's nice to see kids coming up w/ good quality standards these days :)
briteboy
2011 Explorer XLT+Nav,MFT
Shuffle issues
I've noticed that my shuffle doesn't work, unless I maximize the entertainment quadrant to full screen on the center console.
Once I do that the shuffle button is operational, and it does in fact shuffle the content.
But when it's minimized, the shuffle doesn't work at all. Seems to either play in alphbetical order, or by artist.
FWIW...
spr
2013 Expl XLT 4WD
The only trouble with 'shuffle' I have is that MFT seems to get out of sync with the actual iPod I am using once you shut the vehicle off and restart it - as others have said. I dont think it has anything at all to do with iTunes or order of songs in the playlist.
After restart, MFT shuffle indicator might be ON but its not shuffling. I use sync and say 'Shuffle All On', it starts working again. Nothing serious but a small annoyance.
MFT also seems to lose its position in the playlist because of this. Lets say the playlist has 2,000 songs in it. Its shuffling, everything is working perfectly. I'm currently playing song 287 out of 2,000.
Shut vehcle off. Come back, restart. iPod has never been disconnected. Song number now says something like 1273 out of 2000 (but still playing the same song). It is no loger shuffling - its reverted back to sequential order (or whatever order that actual playlist happens to be in.. often alphabetical unless you have is ordered in other ways). Once you turn MFT shuffle ON again - the song indicator goes back to 1 of 2,000 so its currently impossible for me to get through a large playlist without 'restarting' even if it shuffling. Shrug.
The only thing I have not tried is making sure the setting on the iPod itself is NOT set to shuffle before I connect it. I am wondering if the iPod and MFT are both trying to shuffle things - especially since MFT has its own internal index of all songs and playlists etc. Think I'll do that tonight. At the very least - making sure MFT and iPod are in the same state before connecting them with respect to 'shuffle'. Maybe make sure iPod SHuffle is OFF.
I am thinking at this point that MFT is using its own internal shuffle mechanism and not simply controlling the shuffle setting on the iPod. Makes sense if you consider MFT probably uses the same behavior across all media devices and not just iPods. I bet im right - will find out.
** Update **
Nope. Add this to the list of things that doesnt work for me either. MFT is simply unable to keep these settings consistently functional.
Sixonemale
2015 XLT Appearance Pkg
What I've noticed is that you have to stop and switch the media in whatever device you are using to completely shut off "shuffle" or "repeat". In other words, let's say you have it on "shuffle" for a Beatles cd folder, if you turn off shuffle while it's playing this folder it will keep shuffling. You much go to another cd after in another folder after turning "shuffle" off for it not to "shuffle". Again, I hope Ford is reading this and fixes it in the next upgrade.
fyrfyter612 MFT problem...anyone else? 2011-2016 My Ford Touch / In Vehicle Technology 0
D Anyone use the Waze app with their MFT 3.8 or 3.10? 2011-2016 My Ford Touch / In Vehicle Technology 12
T Anyone who updated to 3.0 downgrade to go back to the official 2.2 Sync3? 2011-2016 My Ford Touch / In Vehicle Technology 10
A MFT and MirrorLink? Anyone tried it? 2011-2016 My Ford Touch / In Vehicle Technology 3
T Anyone using Sirius Travel Link weather with version 3.6.2? 2011-2016 My Ford Touch / In Vehicle Technology 6
Z Anyone tried the SCOUT Navigation? 2011-2016 My Ford Touch / In Vehicle Technology 3
R Has anyone figured out how to get messages??? 2011-2016 My Ford Touch / In Vehicle Technology 4
I Anyone download Nav destination from Sync or run Vehicle Health Report since update? 2011-2016 My Ford Touch / In Vehicle Technology 8
E Anyone having difficulty logging into SMR today? 2011-2016 My Ford Touch / In Vehicle Technology 5
H can anyone with nav check something for me? 2011-2016 My Ford Touch / In Vehicle Technology 3
C Air Conditioning - anyone else see this? 2011-2016 My Ford Touch / In Vehicle Technology 14
B Anyone seeing these two issues with the new version? 2011-2016 My Ford Touch / In Vehicle Technology 4
N After upgrade to 2.11 did anyone loose there phone ringer ? 2011-2016 My Ford Touch / In Vehicle Technology 5
Eltee Problem with Dealer and Added On Nav? 2011-2016 My Ford Touch / In Vehicle Technology 2
A New Terrain Management Problem... 2011-2016 My Ford Touch / In Vehicle Technology 1
S Driver Assist Settings Problem 2011-2016 My Ford Touch / In Vehicle Technology 0
C Is this an APIM problem? 2011-2016 My Ford Touch / In Vehicle Technology 13
E Problem with vehicle health report 2011-2016 My Ford Touch / In Vehicle Technology 11
Z Nav problem 2011-2016 My Ford Touch / In Vehicle Technology 2
J Problem Connecting with Sync 2011-2016 My Ford Touch / In Vehicle Technology 1
B Problem with 2013 Explorer sync 2011-2016 My Ford Touch / In Vehicle Technology 3
B Why does an MFT Master Reset Fix the Problem with My Keyless Entry Fobs? 2011-2016 My Ford Touch / In Vehicle Technology 20
B Audio Streaming Problem? 2011-2016 My Ford Touch / In Vehicle Technology 1
T Problem Answering Calls through Bluetooth 2011-2016 My Ford Touch / In Vehicle Technology 1
M Problem using Flashdrive for MP3 files 2011-2016 My Ford Touch / In Vehicle Technology 16
W Explorer XLT 2013 - Maps showing problem 2011-2016 My Ford Touch / In Vehicle Technology 6
VinceL Bluetooth Audio Problem 2011-2016 My Ford Touch / In Vehicle Technology 8
S NEW Problem with 3.51 2011-2016 My Ford Touch / In Vehicle Technology 2
S Turn signal problem, New glich? 2011-2016 My Ford Touch / In Vehicle Technology 0
VinceL Reply to Message problem 2011-2016 My Ford Touch / In Vehicle Technology 7
P Auto Dim Problem 2011-2016 My Ford Touch / In Vehicle Technology 11
P Weird AM Problem 2011-2016 My Ford Touch / In Vehicle Technology 3
R POI problem with Explorer's navigation system 2011-2016 My Ford Touch / In Vehicle Technology 13
2 Problem of a different kind 2011-2016 My Ford Touch / In Vehicle Technology 5
S Bluetooth music problem 2011-2016 My Ford Touch / In Vehicle Technology 0
D iPhone 4 - IOS 5, podcasts problem 2011-2016 My Ford Touch / In Vehicle Technology 0
S Annoying Phone Problem 2011-2016 My Ford Touch / In Vehicle Technology 4
R play list problem on USB thumb drive 2011-2016 My Ford Touch / In Vehicle Technology 4
R Explorer Navigation Tracking Problem 2011-2016 My Ford Touch / In Vehicle Technology 513
E Txt repeat 2011-2016 My Ford Touch / In Vehicle Technology 4
Similar threads
