ASAP: Rought idle, help please | Ford Explorer Forums
symon_say
Dominican Republic
05 F150
I have a 02 XLS V6 4.0L, i have been getting rough idle for a little while so i take it to my local dealer to check what's happenin.
And they told me this:
- Low fuel pressure (i will buy it online cause i can get it half the price they are charging me), is this cause of problems or could it be a dirty fuel filter, i have to change mine but they dont have it right now on stock.
- Code P1151, O2 sensor 2-1 (change sensor)
- Code P1409, lost signal of EVR sensor (change EVR valve)
What O2 sensor is that (in plain words) and what is that EVR valve, cause i only find EGR valve.
The other problems are small thing i would do myself.
Please help me ASAP.
By some miracle I hope your problem is as simple as this:
http://www.explorerforum.com/forums/showthread.php?t=217062
Note, the person who has the V-6 but the same problem. Good luck.
Dayum, Syber, that's a tough problem and some good troubleshooting.
Vacuum leaks can be a cast iron biotch.
I use the (unlit) propane torch method to hunt for them - works great (just don't be stupid - like me once - and accidentally light the torch - doh!).
to the OP, I can't help, but I would agree with Syber - go down his path, at the worst, it's a start. At best, it fixes your problem.
Could you show me about that propane torch method??
try changing the idle air control motor i had to do the same thing this past week i had a bad idle and it would sputter i changed that and my mass air flow sensor
