tires are great. clearance is definitely the issue. whats this I read about f-150 coil spacers?
I made a homemade 3/4" coil spacer and extended the rear shackles 1.5" but I did this when I was running 31's.
My question would be does this F-150 coil job lift the differential much? or is that just front tire size. My experience "comes from straight axle trucks" that lift do not raise your diffs tires do.
The way I'd do it (if diff clearance is your priority) is put in the largest offset camber bushings you can find and then start adding washers (spacers) under the coil springs until the wheels sit straight.
