lsd..aussie locker | Ford Explorer - Ford Ranger Forums - Serious Explorations
lsd..aussie locker
KYLE2289
MARTINSVILLE INDIANA
1994 FORD EXPLORER XLT
ok guys i just ordered all new 4.88 gears for the front and rear to do over the next month and am wanting to order a locker for the rear. i have 3.73 lsd right now and on the Aussie web site they say it only works with open diffs. so don't i just take the lsd out and it becomes an open diff and install the locker or am i missing something.
Thanks for the help.
Explorin'VA
P-twn
'94 xlt
I'm no expert but from what I understand you'll need to install an open carrier for that locker. Or you can find a locker made for limited slip diffs, like the powertrax no slip.
Albino 94LTD
Recovering from Moab 2016
Newcastle Wa
White 94 Limited
Callsign
KG7PKQ
You'll need to install an open carrier for that locker. Or you can find a locker made for limited slip diffs, like the powertrax no slip.
^^This is correct ^^
jmdirk
Ottawa, Canada
'93
Correct. The carrier for the LSD is different than the carrier for an Open diff. The Aussie won't fit in the LSD carrier.
Powertrax would probably be a better option cost wise since if you change the carrier you have to setup the gears again. Most of those lunch box lockers all work in a similar fashion. And they have to be setup properly or they can cause a fair bit of headaches - ask me how I know :)
jd4242
va beach
92explorer&94 ranger
Hes doing gears also..open carriers can be found easily under $50 hell i might have one layn around..but yea powertrax is a good locker also..
Me personally id look in junk yard for a 95+ rear end thats open and swap that in..gain rear disc breaks and get a spare set of axles,always nice to have....i love my aussie and have yet to see anyone break one..
