Auto 4x4 92 Expo Front Bearing Help | Ford Explorer Forums
dykzeulb
KANSAS CITY MISSOURI
1992 Ford Explorer XLT
I was told today that I need to replace the front wheel bearings on my 92 4x4 explorer, does anyone have a walkthrough on here, what tools/ parts needed, I am also looking for a set of front auto 4x4 hubs in good condition so I can do this all at once..
First, I would tell you to jack up the vehicle and pull the rotors off and to clean and inspect the bearings. A lot of times Exploder owners go in for an alignment and the mechanic says it's the bearings, can't align the Ex. When in fact it could be steering or other suspension problems. So first check the bearings yourself and determine if they are bad.
I couldn't really find an old thread with "how to", but for wheel bearing replacement you need:
Parts: Inner & Outer Bearings and Races and a Grease Seal. Timken is the only bearings I use. They cost more, but they are definately worth it.
Tools: Getting the Rotor off requires a magnet for the hub nut key. A 2 3/8" Ford Socket for the hub nut. Every auto parts store has them now. A brass drift with a circular end to pound out the races. You can use the old races to pound in the new ones, but they make a bearing driver set that is better, but you probably won't use it much, so Harbor Freight. The bearing driver set can also be used to drive the seals.
Job:
Remove rotor (which means caliper and hub nut hardware) pull the bearings out and use brake parts cleaner to clean them check them for heat scoring and odd clicks. If they are good keep using them. If they are bad, replace them and always use new races.
Looking through the rotor you should see the lip of the race and an indentation in the rotor, use your brass drift and a hammer to pound out the races. To install, like I said it is handy to have a bearing driver set. You are going to need wheel seals regardless, to check the inner bearing. After putting in the new races, re-install and your done.
If I left anything out, someone else will be chiming in shortly.
Thanks, Matt
technically this is for the brakes, but to replace brakes, you have to completely remove the wheel bearings, so this will show you how to remove the hub, and its components, then remove caliper and rotor, and get the bearings out, then just ignore the stuff about the new rotors, and put your new bearings in the old rotors, and reinstall.
if you need to do front brakes soon, then now is a good time, since bearings and brakes require you to remove all the same parts.
http://www.explorerforum.com/forums/showthread.php?t=122696
as far as buying new hubs, check out rock auto, they are about $200 i think, or many ppl on the forum are selling them, or try ebay.
i bought a set off ebay for only $25
swap those auto for a set of manuals they will last way long and are stronger
I once went in for an alignment and the mechanic told me that my bearings where bad. when in fact they where loose because the lock nut pin had sheared off. so I got a new inner nut and all was fixed.
luckily I caught it soon enough that it didn't ruin the bearings from being loose
If you have a old hard drive they have a super strong magnet in them.
