93FordEx
- October 25, 2012
- Libby, MT
- 1993 Explorer
Hey everyone!
I've been browsing around here for awhile, finally decided to post.
I'm currently majoring in a Bachelor's Degree in automotive technology, so I took some free time today to check out my Explorer and make sure everything was alright for a road trip I'm planning for the weekend.
Bottom line, the inside tread on the front driver tire is completely wiped off, to the point of the steel bands being exposed.
The wheel has play in it, and the Explorer pulls extremely hard to the right. I know the wheel bearing is the culprit, and I had just repacked these about 2,000 miles ago.
Anyways, if the spindle nut just needs a retighten, does driving the Explorer for about 1,500 miles with a loose nut affect the bearing wear? Or if I just tighten it up, will I be okay?
My Main Concern:
If when I dig into it tomorrow and the bearing is in fact damaged, are the inner wheel bearings pressed into the race, or are they simply set loose in there and then followed by the grease seal? Thanks for all your help!
My Main Concern:
