E.B. Cornburner
- April 20, 2007
- Oshkosh, WI
- 2004 Eddie Bauer
This is wierd...Last couple days it's been raining quite profusely here, and I noticed something odd; when I'm driving on wet roads and get on the throttle to either speed up or pass a car, etc. I can feel additional driveline vibration from the front end which indicates to me that torque is being applied to the front axle. Lift off the throttle, and there's a noticeable "bump" as the trasfer case disengages. I wouldn't think the small amount of throttle input I was giving it would be enough to break the rear tires loose enough to cause the 4WD to engage. It also seems to stay engaged too...After lifting off the throttle, and lightly getting back on it still tells me it's in 4WD. Are these designed to do this?
On dry roads, it doesn't do this at all, no matter how hard you get on it.
Are these systems just that sensitive, or should I be looking for a problem?
I've never experienced any others that do this, but none of them had AdvanceTrac either. Not sure if that makes a difference or not...The "AdvTrac Active" message was never displayed on the message center.
