auto hub grease?? | Ford Explorer Forums
auto hub grease??
gogogsr
Montreal
93 xl
Hey guys, what kind of grease do you put in the auto hub mechanism??
You do know NOT to pack that thing full of grease right?
http://www.explorerforum.com/forums/showthread.php?t=206722&highlight=automatic+hubs
This will tell you how to check and clean your hubs. I used this as a reference to clean my hubs but couldn't let it sit over night due to I needed my truck but I did let them sit for a couple hours and I can tell a difference so I can only imagine what the ATF would do if I let it sit over night.
yeah i know, but the grease you put on the spindle at the end, is it bearing grease? Thanks for the info
Thats what I use. And not a problem.
Same here. Just a bit of bearing grease on the splines
