So my hubs are trying to engage. Truck is not in four wheel drive. Question I have is there anything I can do to my hubs till I get the time to put my manueal ones in? Will my hubs do any serios damage if I do keep driving with them.
I am new to the forum and 4WD. My 1994 ranger that I purchased last year will not engage 4WD. The transfer case seems to engage (I hear something) but not 4WD. I checked the rear specs and it is an open rear model 4.0 L engine. I did the axle rotation check and the passenger side will not lock. However, it appears as if the drivers side does. If one of the two hubs are not locking, I assume that the 4WD will not engage at all. Is that a correct assumption? Is it unusual to just replace one of the two hubs? I found a replacement for under $200.00 and I think I can get a new one even cheaper. Also, before I buy a replacement, I am thinking of pulling the hub and trying the cleaning routine. Is there something in particular I should look for that might be broken while I have it off?
Thanks so much. Discovering this forum is a godsend!
