firedog11
- November 1, 2023
- Clarks, NE
- 2001 Ford explorer sporTr
My 2002 Sport Trac with 4.0 automatic will only shift if I manually shift through. I start in 1, then manually shift to 2. I turn the OD off before shifting to D. Once I am up to speed, I can turn the OD on and it shifts. I changed the filter and pan fluid. I don't have a good transmission shop around to take it to. Could this be a valve issue, or is the transmission in need of a rebuild. Thanks in advance.
