miketyree
- July 5, 2009
- weiser Idaho
- '96 302 AWD
I have read a lot of posts on converting to a manual shift with low range but im wondering if you can just keep the same transfer case and convert it into a push button 4WD with some new parts and a little magic?? or do you have to switch out the case too? and then any insight on the two speed sensors up front will that mess them up?
Basically im wondering if you have to change out the TC in order to make it 4WD even without low range?
thanks again
thanks again
