Awd bearing help needed | Ford Explorer Forums
01 limited
Fremont Ca.
01 limited
Im trying to buy a hub bearing for my 01 limited. It's awd. when i look up bearing they are all for 4wd. Are they the same?
Yes, they are the same.
You will need a 32 mm socket to remove the center nut. 13 mm socket to remove the caliper, 15mm to remove the caliper bracket and the hub after you have everything else you have. 10mm to remove the back plate. 5mm hex bit to remove the ABS harness (you don't need to do this normally. Most bearings come wit the harness).
Also, your standard BFH, penetrating oil, jack, and tools to remove the wheel. Leave the nut threaded on and at the end of the threads of the CV axle before you hit it with your BFH.
The Timken bearings are the best bearing for your money. The off brand ones don't tend to last very long, and the motorcraft bearings aren't significantly higher in quality than the Timken bearings.
