Back-Up Light Switch Location? | Ford Explorer Forums
Robb
Hey Guys
I am doing a little work on a '97 F150. The reverse lights are out and getting no voltage. It is a column shift with a 4R70W, so it can't be much different than an X. I am at work and have no access to my manuals. I have a picture of the thing and it looks like it wraps around the shift column above the steering colum, but I cant find it there.
Am I even looking in the right spot? Along the column? Under the dash? On the tranny?
Thanks!!!
THE REVERSE SENSOR SHOULD BE IN THE TRANNY. MOST FORDS THIS ISA PRUPLE WIRE WITH A PINK TRACER.
I just wired my aux reverse light last week.......
Not sure about F150 and Explorers, but as I know, on some other cars it is on the tranny.
WOW! I was WAY off!! Should the purple wire be my voltage out to lights? ANd I can tap that from the outside right?
Thanks!
I believe the tranny is the last stop on the wires way to the actual tail lights, but that may just be my Bronco, plus I am not at home so I dont have my books.
But yes ut should be the purple dude leaving the tranny harness, also you can VERIFY this by pulling a taillight and looking...there should be a ground (black) and te purple going to the reverse bulb.
Youc an tap into it anywhere, although it helps to have a book so you cna trace the wire from start to finish...
I simple soldered a single 12v fog light right in series with the stock reverse lights, tapping into the wires running along the back bumper.......
Works great! Anytime the shifter is in R it is on, even with teh truck off which means I can use it for loading/unloading the boat as long as the e brake is set......
THANKS FOR THE INFO!!
I got a Black and a Black/Red at the bulb and I know it doesn't have juice there. I just wanna check right as it is coming into and out ot the tranny to verify whether it is the switch or before/after the switch.
What a ******* tho! We just had that tranny out about 10K ago. I guess it would have been too easy to put the switch outside the tranny.:rolleyes:
