Back window seal | Ford Explorer Forums
Back window seal
BanGBloW
FL
'08 Sport Trac XLT
Hello,
My 08 back window seal, on the outside of the truck peeled off. Looks like the glue wore out. now i have a huge gap leading into my truck. Does anyone know if there are drain holes down there or will the water begin to collect. I tried to look with a flashlite but cant see all the way through. i know in order to replace the seal the whole window assy needs to be taken out. but im just worried about the water.
The Ford dealer basically just double-sided tapped mine back into position. I don't know about water accumulation down there. Good luck.
what to use to replace the seal around rear window seal that is worn away?
I'm having the same issue, can you order the seal seperately or is it a part of the window assembly? I'd like to replace my seal completely, the original one is mis-shaped and starting to crack.
If you can get the profile of the old piece you can order it by the foot aftermarket.
