Brandon96
- September 6, 2008
- Central Virginia
- '96 XLT 4.0 OHV
Ok, upon start up my explorer will sometimes just sound like it's choking out and won't idle properly, it has neever idled properly in it's life actually, but after a few revs and about 30 seconds of warm up it idles, at least to the best of its ability.
Also, while under really light throttle or when I let off the pedal, the engine starts clunking, it's not a knock, it's quite noticable as the entire truck jukes when the clunking occurs. But it's never a daily thing, it occasionally decides to do this when it feels like it, sometimes worse than others.
Plugs and wires are no more than 5k miles old and seemed to get rid of the problem for a while but it came back. Mechanic says possibly a cylinder was burned too hot at one point in it's life and was fried (no clue what that could mean) possibly piston rings bad? Bad compression? no clue... I've cleaned the throttle body, MAF, TPS and IAC (I beleive that's what it's called, I'm drawing a blank) The truck has a new air filter, plugs and wires as well as a new coil pack. I'm just curious as to what you all think it could be before I dump money into this to figure out what this is. Seafoamed about 5 months, 4k, ago and did help the problem it seemed like for a week or so but it could just be me. (The truck was never seafoamed before that point) I'm going today to get another can to see if theres a better point to seafoam it, (I used 1/3 in the gas tank, 1/3 in the booster vaccuum, and 1/3 in the oil). Oil is about 5k old, Pennzoil 5w-30, could that have something to do with it? This is making me angry, any help is greatly appreciated.
