kamiraa
- March 7, 2005
- chicago, il
- 1992 Ford Explorer XLT
Hey guys. Im have a problem here. I tore my explorer down to do a lower and upper ball joint. I have seperated everything, including pulling off the spindle, im stuck at the part where you have to seperate the steering knucle from the axle arm according to the book. I have been hitting it all day with my hammer from the inside out, and have been prying with a "pickle fork" , (i searched the forum for these suggestions. )
I have so far removed the upper snap ring, and Pitch bolt I think (12mm going Horizontial, I labeled it in this picture .
Then I removed the Bottom Bolt in this picture
Here is a whole shot of where im stuck at here . .
Where do I go from here, any suggestions. Do I just hammer it from the inside of the spindle OUTWARD (hitting from the center of under the car towards the outside of the car), or am I missing another bolt or something I need to remove? The adjuster sleeve is still on there, the part where you can put a flat head socket on the top and twist. What do I do please help. Thanks
-raymond j
-raymond j
