strizzlow20
- January 28, 2010
- Sebastian, FL
- 1998 Explorer 4X4 SOHC
I just replaced my upper control arm w/ball joint and lower balljoint. The problem is is that there is a small gap between the lower ball joint and the knuckle. The ball joint is in the lower control arm perfect. I have pictures but I am unable to post for some reason. I can email the picture to you, I would just like an opinion as to if I need to adjust the ball joint. I am going to post pictures on doing the passanger side now that I have finished the driverside, I just want to make sure this is correct. The alignment place was trying to say the lower ball joint wasn't in high enough so I came home and pressed it in just a little bit more. Please let me know how to post a picture so I can get an opinion
