Made a lot of headway this weekend. I'd consider this the half way point of the front end. Here's where I'm at:
Steering disconnected, pitman arm still attached. Dropped the passenger side beam. Went to fit up the drop bracket but something was wrong. There's an existing bracket in the way! The instructions kind of failed to mention that, as if the original beams were held in with magic. Heh.
So I run out and buy a new dremel and some more discs for the grinder. It was tight so switched back and forth between the two so I didn't completely mutilate my cross member. Those rivets are a ***** and a half.
According to the Superlift instructions you're supposed to drop one beam at a time and do each side on it's own. No way. It's just too crowded under there. I ended up just dropping the entire front suspension. The only thing left attached to the truck was the front drive shaft. I HIGHLY recommend doing this since you're going to be replacing everything anyway and it give you A LOT more room to work with.
So now everything is on jack stands. I removed the existing pivot brackets. Here we are in the home stretch! It's all down hill from here! Right?
Wrong. I line up the passenger side bracket and put the bolts in. The instructions told me to use the 4 larger bolts that came with the hardware kit... That would work except they're too big for any of the flippin holes! Fine. Must be a misprint I have an abundance of slightly smaller hardware that will fit.
Had a hell of a time getting the two bolts on the drivers side torqued to spec. Torque wrench wasn't lining up right with the socket. I finally get the wrench to a spot where I can move enough and watch the pointer ease towards the recomended spec when SNAP! The bolt sheared in half. $@)* I locate the head and yep, there's your problem, Grade 5 hardware.
Cue the trip to McDonalds for some brain food and grab a beer.
When I wrapped up tonight I had installed both brackets almost 100%. I just have to drill the hole for the last bolt on the driver side beam bracket. Thing. I don't know how much one extra bolt will do but why the hell not?
Didn't even both trying to drill because mine is burnt and my bits are too soft.
We're getting there.
