Screamer
- December 27, 2014
- 2004 E350
Parasitic drain test shows SJB Fuse #2 Microcontroller Power / Var1 is causing the drain. Any advice/hints on how to track the problem down further...? Thanks...
Update...pulled the fuse and the windows and door locks do not work. I researched some more and found that either the RAP module or the door lock cylinder is the cause. Now I just need to find the RAP on the 2006 Explorer...
