battery drain | Ford Explorer Forums
battery drain
cneg
2005 ford explorer
hi i have a 2005 ford explorer sports trac and I'm having an issue with the battery draining. I've checked he battery its good and the alternator is brand new and its charging good. also I have used a test light and pulled all the fuses and it still shows the battery drawing. any ideas? thanks
Is it drawing the battery down? How much is the draw?
I'm not how many amps it is drawing but it's enough to kill the battery in about 6 hours
Okay, that's significant. There is a normal draw due to the anti theft and memory saving. But not that much.
Did you do the interior fuses or the engine bay fuses?
I did both the interior and engine bay fuses and I pull the stereo and unplugged it and it still draws
i had same issue, and found out my rear wiper does not work, take the panel off found the motor is really HOT, the motor is shorted inside i guess. disconnect the wire, run the car for a while to charging the battery. issue solved. good luck.
