conig
- July 25, 2003
- tallahassee fl.
- 96 v8 xlt.
I am having an issue with my 2005. about once a week the battery has drained down enough that is will not start.
I have had the alternator and battery checked out and both check out ok.the battery is an optima redtop.
I have removed all accesories one at a time for about a week each to see if they could be causing a drain. They are not the problem.
The dealer did have the motor out to replaced a head for me and I am thinking the engine ground may be off. Every ground I can find feels tight.
would beafing up my grounds help me out? I have intended to do the big 3 anyway so this seems like as good a time as any if its an engine ground issue. I have not found were the engine ground mounts at the block.
