1998 4x4 explorer sport, SOHC, 120,000 miles or so
the drive belt (a/c,ps/h2o pump/etc) was tearing on one side so i put a new one on.
the new one did the exact same tearing (about 1/8 on the side coming apart)
looked closer and found the tensioner was tweaked, it was sitting at an angle because the spring inside had broken or something
put new tensioner and new belt on, but it's still tearing up the drive belt about 1/8 on the back side. i look at it after a short run and i see that the belt is coming off of the crankshaft pulley, and riding back towards the block in exactly the same amount the belt is tearing
i know it's a ribbed belt and seems odd that it would do this, but it sure enough is
i've put the same belt back on it that it had original equipment, and the tensioner is one i got from O'Reilly's for about 45 dollars. It looks to be the same thing as the original part, but i'm not sure if the tension amount is the same.
any ideas on this ?
thanks,
dld
any ideas on this ?
thanks,
dld
