Chrome_Rush
- November 17, 2014
- Dearborn Heights, MI
- 1991 Ford Explorer 2wd 5
I'm going to be upgrading the stereo in the next few days, haven't decided If I'm going to run a 4 channel amp or not, if I do I will run zero gauge wire to the back, but most likely I will just be running an amp for a sub and using 4 gauge. Is there a known good spot to run either 4 or zero gauge wire or is this a vehicle you just have to drill a hole in the firewall on? Usually there is at least one easy spot to run the wire on most vehicles. I hate drilling and risking drilling into something. It's a 5 speed 2wd 4 door. Is there maybe a hole where a shift cable goes through for an automatic I might have open?
