Best Speakers | Ford Explorer Forums
Best Speakers
playa3216
Speaker Hookup Assistance!!!(Please Reply)
Can anyone help me on the best way to install 5x7' or 6x9' speakers in the door panel? I know my 91' Explorer that has a wire harness that has prevented me from installing new speakers to replace the old one. Any tips will be appreciated!! Thank you!
Its actually pretty easy. You pop the door panel fasteners off, then gently pull away and undo the harness to the power equipment switches. I believe any 5x7 or 6x8 (6x8, not 6x9) will fit in there. It should be as simple as unscrewing the old one and putting the new one in, making sure to get the correct polarity. If the old one has a harness, it should only be with two wires, so you cut the connector off and just splice the wires into the new speakers. It took a friend of mine and I about 45 minutes to replace all four speakers.
Good luck!
Oh, and welcome to the board!
