BIG project in Feb 2011 | Ford Explorer Forums
00whxploder
Fitzgerald, GA.
2000 xls 4x4 now
Okay so i'm doin a big project here in Feb.
http://www.explorerforum.com/forums/showthread.php?t=367063
First i'm goin from 2wd to 4wd.
Second the beef up.
Third the up.
2wd-4wd
i have found
bw 4405 t-case i need for the 5r55e trans. $350 at the high
4x4 4dr rear drive shaft $95
4x4 hubs and bearings $128
Dana 35 front axle $250
Front drive shaft $105
Front cv axles $140
Also instead of buying the 4x4 knuckles I decided to get the superlift 4 inch lift with the knuckles $1800
The Beef
Power trax front lock right locker $265
Eaton eLocker for the rear $770
Dana 35 bearing rebuild kit $100
Ford 8.8 bearing rebuild kit $90
Front and Rear 4.56 ring and pinion gears $350
The UP
Superlift 4 inch lift kit and the pa 883 3 inch body lift $1975
Then do a nice set of 35's then performance will come later.
total with out tires $4871
Let me know if I missed anything
Its okay i have finished this finally just bought a running ex for 1000 and put it all in mine got tt shackle and body lift on 33s and it runs great.
Any pics?
