Binding steering after 3" body lift | Ford Explorer Forums
orty
Weyburn, Sask.
'92 XLT
I installed the PA 3" body lift, and used their steering extension. Now it is binding.. I was wondering if anyone has removed the extension, and replaced the factory "canvas knuckle" with a small agriculture ujoint????
Binding
Hey dude, What did they give you when you received your lift? I didn't get anything for steering with mine, at first I had a slight bind, then I grabbed the Dremel and at the base of the upper and lower u joints on the inside bottom of the "U" as you're looking at them, I ground out just a little bit of material. No more binding.
Hope this helped
Good luck.!!!
I got the steering extension with it.... It is a very sloppy fit. I shimmed it up and seems to be a bit better. Im going to look to see were it is binding and maybee dremel it out if it is....
