well friends , i checked the cooler lines and the cooler itself and the radiator part for cooling gb oil ,, all ok , no blockage ,,, i blown some air into the cooler and radiator too with no sign of blockage ,,,
but i noticed few things :
when the car was cold and before starting it in the morning , i checked the oil level of tranny , it shows very high on dip stick ,, say about 2 cm higher cross lines. but when i just start the car , and check the oil level on stick , it shows very very little or no oil on stick!!!
where the oil is gone ???
again when it gets hot , on parking , little oil on tip of stick !
the other thing is when i opened the cooler line which connects to the radiator (upper one ) just to see the flow of the oil throgh the line it was very little oil coming from it , not that quantity i know when i did my last time tranny flush through cooler lines ,
so i think this could be to low oil pump output ???
low oil in torque convertor ???
oil leaking inside , my be towards the back of tranny (can see some oil leakage near the 4x4 part and the back exten. part of tranny )
or may be my friends brooklyn bay or glacier can give me explanations
or ideas of what else to check or replace .
thanking you
