Bleeding ABS brakes. | Ford Explorer Forums
Flintjon
Carmichael CA
2001 XLS
Hi to all
I am looking for information about bleeding brakes on 01 explorer 4-wheel Dr
ABS.
You will need that scanner if the air that was allowed to enter the system reached the ABS pump. If the air did not go that deep into the system, it can be bled like any other brake system.
bleeding brakes
I was afraid of that I'll take down and have a shop do it. Thanks flintjon
from what ive heard you can bleed them the regular way if no air makes it that far that it gets into the module. but if it does i also read that some Code scanners will sequence the pistons? in the module to get the air out. if there is air in the module.
You'll be fine as along as you keep the reservoir full just start with the back passenger then back driver, front passenger, front driver. I've done quite a few vehicles with abs and have never had a problem with getting air in the system.
I haven't had any issues with the air reaching the ABS pump either. I use a vac pump to bleed the brakes, alot easier and a one-man operation.
I also use a vac pump and it works nice on my bike and PU but wouldn't work on my ford. I took it to a shop and they had to use a scanner to get the air out. Thanks to all for the information it did help. flintjon
