At a loss, in need of help!
I have been having this issue with my explorer. I have a 93 4x4 that has had a weak break pedal since I bought it about 2years ago. About a month ago I finally got around too replacing the master cylinder hoping too resolve my issue. After doing so the truck has no breaks. With the key off it builds a minimal amount of pressure, but when running goes straight too the floor. The rear breaks barely work and the fronts don't work at all. I have been chasing a break problem ever since. I have replaced the master cylinder 3 times, got 2 new calipers, re-adjusted the rear shoes and bled everything multiple times. I came to the conclusion that there was air trapped in the ABS hydraulic unit (HCU). I read somewhere online that it needed too be taken too ford too be electronically bled if air gets inside. But when I brought it too the dealer they said that an anti-lock break adapter (T90P-50-ALA) and a Jumper (T93T-50-ALA) were necessary too bleed the ABS unit, but both my ABS unit and both tools needed too bleed it are obsolete and that they can't even get ahold of them. This it my last hope of fixing my breaks. If anyone has any information on how too fix this issues of how and where I can acquire those tools would be much appreciated
-Joe
