a4angiel
- November 18, 2001
- Palm Bay, Florida
- '92 XLT
I am having a bit of trouble with my blower motor on my 92 X. Right now it is moving air on High and Off. I have found other references to similar problems, but nothing with the blower working when i is swithced off. The resistor pack looked fine, and my ohm meter indicated slight and varying resistances using each of the tabs. There appears to be 12 volts on the pink/white wire in all switch positions. According to my Haynes, there should be no voltage in Off. I'm thinking the problem may be in the control switch inside the X. Has anyone else experienced this type of behavior?
