AlaskanJack
Elite Cabin-Fever Captain
- March 24, 2002
- Centralia, Washington
- 91 , 93 & 01 Sports
Well my buddy and I got together to do his 1" body lift. All was going sweet and fast then we had a problem getting the front bolts out of body mounts in front of engine. well we jacked up the truck enought to slide the disc over the bolt and we pressed on from there. we completed all the body mounts and then came back to the front only to realize that there wasn't enough threads sticking through for the front body mounts.
Neither of us knew that the front body mounts screwed together so we hit it with penetrating oil the heat then hammered on the bolt top until we boogered the threads. He finally got a cutting wheel and cut the bolt head off. when we pulled the body mount out we discovered the additional threads in the body mount.
We are going to do this 1" body lift to one of my Explorers next and need input on removing the body mounts without cutting the bolt heads off. We tried to lock vise grips on the round metal top of bushing without success. If you removed the front body mount tell me what you did.
