your right, a-armed suspensions don't have coils, that should have read TT or spacer up front...I missed the 98 part.
The body lift isn't any less safe than a suspension lift.
First, your kidding right
So replacing your grade 8 factor body bolts with a much weaker tensile and yield strength bolt is safe? Not to mention separating your body from the frame of your vehicle? You have obviously never seen a vehicle with a body lift after it has been hit in an accident. Most fab, off-road, and suspension companies won't go near a vehicle with a BL on it due to the liability issues. I could list a number of problems associated with BL's but why? Just call up any reputable company and ask them.
Second, those soft...thin...bumper brackets
do not by any means replace the strength of your bumper being bolted to the frame in its original position. It takes very little pressure for those cheap bumper brackets to bend and shear off. Your bumpers are there to absorb and protect the vehicle from impact, neither of which those flimsy brackets can do. Like I said earlier if your going to go with a BL at least have your bumpers welded to the frame instead of using brackets.
Third, I can think of a number of companies that offer basic suspension lifts for the second gen for around $600.
a suspension lift raises the under carriage higher from the ground
The only way to get more ground clearance is to increase your tire size...and this is the only way. Hence the reason for lifts,.. to accommodate larger tires. There are plenty of other benefits to a suspension lift as well. You get the added strengths with upgraded suspension components, and greater flex and off-road mobility. Much stronger and much safer than a BL.
Yes...BL's are quite a bit cheaper than a suspension lift, but are cheaper components really what you want when it comes to the performance, handling, and safety of your truck?
These are just the facts plain and simple there was no need for you to get offended. Everyone is entitled to an opinion and I was just trying to explain the benefits to waiting and or saving for a suspension lift.
this is what can happen with a 3" PA bodylift
this guy was lucky to walk away! The body completely separated from the frame upon impact. His 3" PA body lift bolts snapped in two.
If you'd like to read the thread on this accident I'm sure I can find it.
