body lift question. | Ford Explorer Forums
body lift question.
Michigan
2000 XLT
If i do a 2inch body lift on a 2000 ex would i still need a stearing extension? or how high could i go on one without buying an extenstion?
I COULD be wrong, but I believe with the 2'' lift you would not need the steering extension.
Bumpers. Or else you'll have a 2 inch gap.
This is correct. I installed the PA 2 inch about a month ago and initially removed the steering column bolt in the engine compartment, but found after installing the lift that this was unnecessary.
